1 - 13 of 13 Posts
I will have a 4 inch lift, Ford 8.8 with 4.88 gears and pinion angle +15 degrees for the lift, an SYE and a double cardan driveshaft. Will the the pinion offset to the right side cause vibration issues? I is almost 2"?
not with the SYE. I would do a 3.5 inch coil in the back, 4 inch coil in the front. The axle tubes are bigger, requiring less "lift" in the back. IIRC, my rear is 2 inch and with 3 inch coils and a 3/4 inch spacer in the front for winch weight I sit level.
The JB conversion looks awesome. My transfer case speed sensor is a gear, not electronic. Does it come with some type of conversion? The hole is much smaller.
I just read the install instructions and it does come with a tone wheel and sensor for the speedo. How would you adjust the speedo output signal to compensate for gears and tire size?
Mine vibrates at 60 on up, done everything to try and fix it, switching to a JB super short here in the spring with a different transfer case too, hopefully it works.
I have a Zone 3" and yeah the rear is up higher because of the bigger axle tube.
I had an 8.8 in my last TJ with about 4" lift . I just used a regular Advanced Adaptors SYE and a TW shaft . Never had an issue
You might want to consider a super short sye like this one from JB. JB Conversions, Inc.
I've been running one for a couple of years and it's been excellent.
I'm currently shopping for an SYE and I've been looking for a Super Short unit. This looks like exactly what I'm looking for and well-built beef.
I haven't been able to confirm but it looks like the super short only works with Jeeps that have and electronic speedometer. Mine is a 2003 and uses a gear for the speedo. The gear is connected to an electronic signal generator but I think that is referred to as mechanical vs the tone ring type.
Does anyone know what year they became electronic? WaterDog, what year is your Jeep.
Lift is finished. It is a RC 4 inch long arm suspension lift with a ford 8.8 and disc brake conversion. Regeared to 4.88 front and rear. The front is still a low pinion Dana 30. I put in an Adams DC drive shaft and an SYE. New alloy wheels and Nitto Trail Grabbers. I have vibrations at highway speed. It is felt through the seat and is constant and very rhythmic. Much less noticeable coasting than acceleration. Tires are balanced and a local 4X4 shop aligned it and did final adjustments (including pinion angle) on the lift kit.
As you tell from my first post I was concerned about the offset or the 8.8. Most everyone says with a DC driveshaft there is not issue. I haven't pulled the front shaft to see if that is the problem but it wasn't an issue before the lift. I replace so much stuff I am not sure where to focus my efforts. Any suggestions?
BTW, everything is better with the 4.88 gears vs. the old 3.07.
Full Size Jeep Dr.
Start with tire/wheel balance. TJ's are sensitive to it.
Tires give a shake, driveline gives a vibration, I know the feeling you are getting, I'd try a SSYE for a longer shaft to reduce some of your now compound angle due to side offset.
Yes, the offset pinion on 8.8" axle can cause vibrations. That's one of the reasons I don't recommend them.
1 - 13 of 13 Posts
