Looking at using Herm's steering box upgrade for my 67 CJ5/V6. Herm recommends using the Ford reverse rotation steering gear from 80-97. Every one I looked up has an 3/4" input shaft with a spline count of 29 with a flat. Is this the same as the very common 3/4" steering U Joint with a spline count of 36 by not counting the splines on the flat?
The answer, I found out, is that when there is a flat you divide the shaft end in half count the splines and double it. So therefore a 29 spline steering box does take a 36 spline U-joint.
