I just wanted to post this in case someone else ends up with a similar noise. I have been experiencing a noise ever since I bought my jeep a little bit ago. It seemed to only do it when the jeep would rock back and forth or hit a good bump. I would always hear it when I drove down or up my driveway as there is a good bump going up and down. I went out today to inspect my suspension parts and turns out the passenger side coil/spring is rubbing against the frame of the jeep.
Below are some pics. The first one is of my driver side with no contact. The next 2 are of my pass. side where you can see there is contact against the side of the box/frame thing there.
As far as fixing this......Can I just pull it off and move it around to get it away from the frame?
Also, not to take away from this thread, I bought the jeep with what I am assuming a leveling kit type lift, is that right? There are rancho shocks and rubber things on top of the coils all around. So does that mean mine has the 2.5 in lift on it? Or is this a stock setup? I'm going on a limb here and going to say this isn't stock.
