1 - 14 of 14 Posts
Recently discovered some weak spots in the frame near the rear shackles, starting to rust threw and become holes. And also the Trans mount has rusted threw. anyone else have this problem? If so how did you fix it?
yep,doing one now..it's got to have new steel on it..you can either cut the pieces yourself or buy the frame repair sections and weld them in
Looks like its time to get out the grinder. Any thoughts on the transmount? I think it is this because I have a lot of differential movement pushing in the clutch with a load on the engine in first gear. May be completely wrong but I can't figure out what else it could be.
I just replaced my crossmember/skidplate it is a common problem for rot, I picked one up at a local Jeep salvage yard for $60
Discussion Starter #13
Thanks I think i'm going to try and repair before Chicago weather sets in. I don't want to risk it.
1 - 14 of 14 Posts
