Anyone else had issues with the freedom panel filling up with water during a heavy rain? Will drip all over the inside area as you turn corners till I either remove it and drain it, or it all empties inside the vehicle. How is this happening?
A buddy of mine has this happen. When he hits the breaks the water drips on the tuner. Turns out the issue is he was only running with one top panel bolt attached instead of both.
Yeah i have that occasionally. Usually in very heavy rain or lawn sprinklers so im pretty sure its a particular direction of water that gets inside.
Wrangler freedom top leaks are VERY common, but it's mostly due to poor or inadequate rubber sealing. (Do a search and you'll see many posts on this).
But, are you saying the panels somehow fill up with water and you have to take them off and drain them??
Like FJMOMO says in his post.... I've never had that problem.
