Same here.FWIW, I almost never put my panels in the bag. Usually I just lay one white side down in cargo area, then lay bag on top, and put second panel on top of that black side down...
Joe
I always use the freedom bag. The main perk is the strap that keeps the top panels vertical against the back seat. This allows you to use the cargo area with limited obstruction.I just bought a Wrangler...used great condition but it didn't come with the freedom bag.
Looking at them maybe I could just wrap them in a,blanket...do the bags protect the covers and can you store them on the side instead of behind therear seat. It's a 4 door ...thanks
Better buy a,bag...I do not want to ding those panels...I'd use the bag, don't want those panels sliding around.
Seconded, I have the Rampage bag too. Works great.The MOPAR bag can be tight, I found it really inconvenient to use and it was wearing the foam weatherstrips on the corners. I picked up the rampage bag, much easier to use. It does use much more space though if that is an issue for you.
Ha! A longer zipper would've made it a much easier task.Putting the panels in that bag is like a sobriety test.
Do you have,the Rampage bag or the Mopar bag. I think I will get the rampage... It can t be that hard,to put,the panels in...I dont understand why ppl are having such issues. its really not that hard... lay the bag flat while u do it...
I use the mopar one that came with the jeep. There's even directions inside that tell you exactly how to put the panels in.Do you have,the Rampage bag or the Mopar bag. I think I will get the rampage... It can t be that hard,to put,the panels in...
