what is the best way to install rear mtr blk freeze plug on 4.0 with out pulling moter there is not much room between mtr. and fire wall ?? any help will be greatly apprieciated.:confused:
I don't know if it will work, but I had the same prob with a big block Ford. I found out that there is a type of freeze plug that needs no hitting-in, but instead you tighten a nut in the center of it and it seals.
