Hello all. I have a 2014 JKR with 3K miles. I noticed fluid on my front drivers side LCA and garage floor. It is coming from the top of the axle breather hose. Everything bone stock for now. Has anyone else had this problem?
Could just be overfill from factory spitting out ..mine did it on rear and sprayed up all over ..not a big deal ...dealer will even drain and refill to proper level If you take it in
If you don't want to take it to the dealer all you have to do is when level open the fill plug and see if some gear oil leaks out. It should just be filled to where it starts to slightly weep out. I would check both difs., or have the dealer take care of it under warranty.
A forum community dedicated to Jeep Wrangler owners and enthusiasts. Come join the discussion about reviews, performance, trail riding, gear, suspension, tires, classifieds, troubleshooting, maintenance, for all JL, JT, JK, TJ, YJ, and CJ models!
