Hello, I'm wanting to rebuild my front axle d30 on the TJ and I plan on getting chromoly axles with the aussi locker and new ring and pinon. Wanting to know is there anything else i will need or should upgrade and what brands you guys recommend. Also what difference do splines on the axle make and teeth on ring and pinion? What ratios do you recommend? Thanks for the help.
We need to know your tire size, engine, and transmission type before suggesting a gear ratio.
You should source the locker and gears through the shop performing the gear swap. Chromoly shafts can easily be installed by yourself.
