I tried to install my new poison spider brawler mid front bumper but can’t line up the driver-side studs. Passenger side will lines up but the driver side doesn’t look close. These pictures are of the driver side with the passenger side studs in their holes just enough to hold, not even far enough in to start a nut yet. Is their anything I can do or just call customer service tomorrow?
Get out a tape measure and try to determine where its off, drilled wrong, maybe not jigged right when welding together, etc. That will also help out the vendor if you find something wrong. Do the same to the frame horns your bolting to. You should be able to identify the issue pretty quickly. Good luck
Holes match up passenger to driver side, had variances between the studs.
When making measurements I noticed the passenger studs had play and not the drivers. Turns out they should have play, gave a little persuasion to the drivers side to break the free from the powder coat and everything went together flawlessly.
