I am getting ready to pull the trigger on a 3" Zone lift for my '01 TJ. For the time being I will be running factory control arms. I plan to use the transfer case drop that comes with the lift, do I need to go ahead and order the $30 cam bolt kit as well?
I have read where some guys use them and some don't. But, I have also read where you don't really need to do a t-case drop at 3". This isn't my daily driver but it does see more pavement than dirt so I want to keep the drive as comfortable as possible.
Any info from others running 3" lifts would be greatly appreciated.
Knows a couple things...
Front cam bolts are useful for minor caster angle adjustments but that would not be required for a 3 inch suspension lift. And you're definitely need to do a small tcase drop for a 3 inch suspension left to eliminate the drivetrain vibrations it will cause.
