Hey everybody! I'm new to the Jeep family. I have a 2014 JK and just 4wheel parts put a 3inch rubicon express lift on it. I noticed when I was doing some work on the from bumber that my front right coil spring is sitting a little crooked. Anyone know what could be the cause of this and what I need to do straighten it up??
Thanks.
Is the opposite side spring leaning the same direction? Is your front axle centered under the vehicle?
Take it back to 4 wheel parts, make them fix it.
The bump stop looks centered so I don't think it is a seating issue. Looks like the axle is way off to the drivers side... Common when lifting and not using a high steer kit or adjustable front track bar.
If you have either of those, they installed poorly... If you have neither, you need one of them.
Yep. Add an adjustable front track bar to center the axle. If it's already adjustable they did not center the axle correctly.
