1 - 12 of 12 Posts
I was wondering if there are strong opinions on who makes the better front drive shaft:
Tom Woods
JE Reel
Coast
I did a forum search and it seems to be an even spread of these three. I figure I will need one soon enough and would like to hear pros and cons of these, or if there is a better brand out there.
All three are good. I bought a JE Reel because that's what the guys at Full Traction, where I bought my lift, sell.
Put twelve Jeepers in a room and make em choose among the three, and my guess is you'd pretty much get 4, 4, and 4.
I don't know of a downside to any of them.
Up to a 3" lift, you'll want a 1310. Above that, a 1350.
no retreat, no surrender
X2.... what kbwwolf says... and same reason for choosing the JE Reels.... that's what the guys at Full Traction recommended. They did my lift. I went ahead and did both... (even though they told me I could wait)... I'm out by myself a LOT... and a tow from most places around Moab is the cost of a DS... that's called dame reasoning :thumb:
Thank you both for your thoughts. Would the 1350 be too large of a diameter for a 3 inch lift and end up hitting the exhaust again? The extra large u-joints would be nice, but may be overkill. Extra stength in a driveshaft is a good thing I would think.
JE Reel says the 1310 is good for lifts up to 3" with 33" tires.
I have a 3" lift with 35" DuraTracs...but they're closer to 34's than 35's, and are one of the lightest tires you can buy.
Most of the folks I talked to – including Steve, one of the Full Traction engineers – said the 1310, which I'm running, is more than enough for my setup.
If you're planning to run a really heavy combo like 35" Nittos, you might wanna consider the 1350. Marinehawk is running one with his 4" lift and 35's. I don't think he ran into any clearance issues.
Thanks wolf. Yes, I saw Marinehawk's build and he is going heavy on almost all counts. I'm using some of the same components but will have 33" Duratrac 285/75 R16's with a 2.5" RK lift (may change that). After looking around I think I'll go JE Reel 1310 also. Did you do the stock replacement or did you change the flange out?
I bought the OE replacement.
That should be plenty for you, if you stick with what you listed above. In fact, on their own website JE Reel says that a # of their product vendors sell the 1310 to folks with up to 5" of lift, apparently with few problems...but they don't recommend it (almost certainly for liability reasons).
Any of the three mentioned driveshafts are good. I'm using a Coast 1310 because that is what was recommended and it was cheaper than the others. I've put 3500 miles on it so far with no problems.
The main reason that I chose a 1310 over a 1350 was because I didn't need the heavier duty driveshaft. I've read the the beefier 1350 won't flex as much as the 1310 because the u-joints are bigger and won't allow for more angle, but I don't know that from personal experience. I was also told by a guy that does JK hemi conversions that he recommends a 1310 even if you have a hemi because it is cheaper to fix the broken u-joint of the driveshaft than it is to repair something that breaks in the axle or transfer case. The 1310 u-joint would be the weakest link in the drivetrain. Adding the 1350 could cause something else in the drivetrain to be the weakest link for breakage.
If you limit your lift to 27.5" long shocks and a 1310 shaft it will clear the exhaust with no mods needed.
IMO I would stick to 1310's even on 37's. That way your u-joint is the fuse on the driveline and not your ring and pinion.
Discussion Starter · #12 ·
Thanks for the reply! I think that is the way I will go.
1 - 12 of 12 Posts
