1 - 9 of 9 Posts
Will have time tomorrow night to actually look at it, just was able to test tonight when I got home.
Passenger side Rear, Front and Fender all work correctly.
Driver side Rear works correctly, Front and Fender do not come on at all.
Where should I start?
Welcome r3con. To help us help you, take a look at the below Link and then fill out your Signature.
https://www.wranglerforum.com/f218/a-better-way-to-get-help-in-the-yj-tech-forum-2341475.html
As for your blinker, The fender does not blink, It's just a side marker lamp. When I started on mine here's what I did, Since they are all on the same circuit off the fuse block you can rule out the fuse.
1. Check your bulbs, A Volt OHM Meter is going to be your friend. If you can't visibly verify the bulb you can either OHM it out, or swap it out with the other side.
2. Check for voltage at the socket using both the socket and a known good ground +/- 13v. If you have voltage, trace down the ground, could be the fixture, could be the groundwire at the tub. just above the headlight relay to the left of the drivers side headlight. Sand down all surfaces with an emery board or cloth, reassemble with Di-Electric grease.
3. If that doesn't solve it, There's a link at the bottom of my signature that has FSM's for almost all the years, Pick the one for your year and you'll have access to diagnostic flowcharts and wiring diagrams.
Good Luck
That's a 2 filament bulb. Make sure it is in the socket correctly.
Check Terminal Block
If all else fails, check the wiring terminal block on the inside firewall just behind the washer fluid tank. The wire for the marker/turn signal on both sides goes through there. I have found corroded terminals in this area to be an issue.
Thanks for the info guys, and on the passenger side my fender light does blink with the blinker, which is why I say the driver side.
Out to the garage.
Ummm... My side marker lights on the fenders DO blink with turn signals.
They may have changed in later years, OP still hasn't posted what he is working with so I did not check, but not in '89, running lights only.
1 - 9 of 9 Posts
