When braking the front end shakes. It is sort off like a bad shock??? I not sure what could cause this?? Anyone else have this problem?? Thanks, Dave
ABS is an option on a wrangler, $600 bucks I believe. I opted to not have it, but some do.Do we have anti-lock brakes? First time mine kicked in on my truck I though the front end was gonna fall off!
X2Warped rotors.![]()
Do you have a machine to turn rotors??Odhinn there is an x2 above lol so you are x3 and i'm x4 on warped rotors :flipoff: Have some one machine your rotors or you can replace them but machining should be cheaper. If you were closer i could have done that for you
My company car is a cherokee 98 that had abs.. we would replace the rotors and a month after it will be trash again. So far all my cars no abs.. no problems...
ABS will not cause warping, it has nothing to do with brakes in that way. The ABS system even only does anything when it detects a different RPM between the wheels.My company car is a cherokee 98 that had abs.. we would replace the rotors and a month after it will be trash again. So far all my cars no abs.. no problems...
The school that i go to does and i know how to work it so i can bring stuff from outside and work on it.Do you have a machine to turn rotors??
