Hi guys looking to grease my front end. found the grease fittings. Just need to find out what kind of grease I should run, and where will it be coming out of. Thanks.:thumb:
im not sure what grease my dad uses (mechanic) but i grease em up till i see some of it squeeze out of the rubber seal usually.
I just use the SuperTech (Wal-Mart) Hi-temp Extreme Pressure wheel bearing grease, lithium-based. The reddish-purple stuff. That said, you should be good with anything labeled for use as chassis grease. Check the NLGI rating on the container. Careful with the amount you force into the boot, if any of them is old and cracked it may burst. You just need to get it firm to the touch.
