1 - 20 of 25 Posts
Retired Moderator
Hey guys,
I am looking for a front upper control arm bracket kit (or separate). This will be for an XJ, but they are identical to TJs as far as bracketry is concerned. Unfortunately, it is easy to find kits that are "universal" accepting a control arm bushing/joint but not so as many choices for axle-end bushing/joints. What have you guys found?
Retired Moderator
Discussion Starter · #3 · (Edited)
Thanks bud, but too rich for my blood. Also, the axle that is going into the cherokee doesnt have any brackets on it, so this cant be used without fabbing something additional up. I also need the diff bracket, not just a replacement bushing/joint.
I need something similar to factory, but stouter. The diff side joint will probably end up consisting of a truss set up since there isnt anything cast into the diff.
Thanks bud, but too rich for my blood. Also, the axle that is going into the cherokee doesnt have any brackets on it, so this cant be used. I also need the diff bracket.
The cast upper diff bracket is gone?
Think this is about as cheap as its going to get: http://claytonoffroad.com/product_info.php/cPath/18_71/products_id/290
Otherwise I think you are going to look at junkyards.
If you were close by to me I would sell you my complete rust free 06' Dana 30 axle which has all the brackets for $75.
Rock-Rubber
He's not asking for stock just stock style.
Have you looked at ruff stuff or ballistic at all con? Although I have heard nightmare stories about ballistic they might have what your looking for.
As for arms are you running stock arms or a bushing both end arm.
Retired Moderator
its all in the details, huh NJO...JK
have you thought about custom mounts? maybe a truss?
with all that work, i wouldnt be using the stock brackets
I don't want stock brackets...just stock-like brackets. The reason being, the cherokee is being built for the Everyman Challenge at KOH. With this, the suspension needs to remain similar to that from the factory. The time it would take to build the brackets isn't really worth it since we are building out of our garage and dont have all of the tools that would make it a 'simple' job.
Retired Moderator
I have looked at ruffstuff...their stuff is more universal link-style stuff.
My buddy looked at Ballistic and said they didnt have them...may have to look myself though.
I checked out poly performance also with no luck.
We have found a kit from rubicon express...but there has to be something else out there. Not that we are against rubicon express, just trying to find more options.
The arms will be factory like...with the bushing being on the axle side.
Unfortunately the OP didn't give much in terms of details originally, and his budget seems limited for the project, and the assumption is that he doesn't have the means to fab one himself. Didn't know this is a raw swap from a Ford Dana 44.
Rock-Rubber
Got ya. Think about contacting artec and see if they have something. They might have the files for the 44 from a custom build or could do one up for you. With a truss and all brackets. Probably not too much. They are a great company to work with. At least shoot them an email and see what they say.
Retired Moderator
Discussion Starter · #13 ·
We have the 'means' to fab them ourself if necessary...but with the cost of most brackets on the market, it would almost be dumb not to buy them. Between material, fab time, and guesswork...you really cant beat the price of most brackets that you find prefabbed. But a setup for the TJ/XJ front end appears to be pretty limited...thats why I am asking.
Retired Moderator
Discussion Starter · #14 · (Edited)
Not a bad idea, they didnt have anything listed...but custom may be available.
OP, curious, whats the end goal in terms of tire size your going to run to be going with a HD "true" HP44? 37's or larger I assume?
35s...Everyman challenge stock class limits us to 35s.
Retired Moderator
Discussion Starter · #16 ·
Yep I would hit up artec and see what they say. I feel like I have seen d44s on their fb page with custom trusses, ram assist steering, brackets, etc. I'm sure they will either have something or offer to build it.
:thumb:
I am running the RE9968 kit from Rubicon express on a HP dana 44. You can buy just the pieces you need, like the truss and upper mounts.
1 - 20 of 25 Posts
