1 - 9 of 9 Posts
Will also include the Superchips Dash mount part#38302 and TraiCal part #41051. Have parts and box as well.
I called Superchips and they said it will work on all 07-18 JKs. When I asked why the different part numbers they said the Trailcal is specific for 15 and up and they also offer a TrailDash 2. They only made a TD2 for 07-14 and not a Trailcal since the 12-14 doesn't need a PCM swap for tunes. Because a PCM swap is needed on a 15 and up JK for tunes, Superchips created the TrailCal that does everything a TD2 can but with no engine performance tunes. You don't need a PCM swap on a 12-14. So you could buy the TD2 or upgrade this trailcal to a TD2 for $70.00 for 2003-2014 year.
Per Superchips site the Trailcal can be upgraded below to:
15-18 TD2 for around $170
2003-2014 TD2 for around $70
2018 JL TD2 for around $170.
$300 shipped OBO. More pictures added.
If you don't mind, please confirm the Superchips unit was unmarried from your Jeep. Only an unmarried unit can be used on another Jeep.
Yes. I factory reset the unit so the vin is unlocked and updated to the current firmware. Good looking out. Thank you.
Also have the code to override factory TPMS setting. Will include that as well.
1 - 9 of 9 Posts
