i may have ruptured the fuel line that goes from the frame rail up into the fuel rail. gonna pull it apart tomrw and see if it can be salvaged, but it's leaking badly when the sys comes under pressure from the lower connection.
i cannot seem to find it from auto parts stores to jeep outfitters, i did find several on Ebay used (this can't be a good sign).
anyone know of a source for it or an equivalent alternative, any high pressure fuel line would work if the connectors are right.
I used two quick connectors and a 6an fuel line. Might be an option for you too. Mine were 5/16”, you should double check that your model year didn’t change to 3/8” of you decide to go this route. I also added a fuel pressure takeoff adapter and gauge right by the fuel rail.
https://www.amazon.com/Russell-640863-Quick-Disconnect-Female-Fitting/dp/B001P29076
https://www.nitrousexpress.com/12073-d-6-6ft-stainless-steel-braided-hose-red.html
https://www.amazon.com/Russell-670340-Anodized-Aluminum-Pressure/dp/B000CPILAE
https://www.amazon.com/Marshall-Instruments-LS00100-Liquid-Pressure/dp/B01GQNVDDW
thanx .........
ok, so just for future ref. there is an after market replacement the Russell 651111 fuel hose, about 60-65$.
i ended up using the Dorman 800-080 connectors and the 800-074 tubing for now.
and i'll rebuild the bottom end of the OE pipe, and then have my temp as a spare.
