1 - 11 of 11 Posts
I've been looking for a while and I think I've landed on the glossy black & milled Mavericks for my 2015 JKU. My question now is, what size wheel do you think would look best and on what tire? I plan on getting a 2.5 lift, and I think I will likely go with 33" tires.
I saw some pictures of 20x10 on 33s from 2012ArcticBeast (which look great), but also curious what smaller size wheels might look like if anybody has them?
33's on 20's not so sure. 20's on 35s on the other hand...
don't do it!! mavericks suck if you use your jeep as a jeep. The valves are in between the spokes. Airing down/up is a PITA due to the location. Also, I had the multi hole (10) bolts. that makes it worst trying to put the rear spare tire by yourself trying to align 3 bolts out of the 10. Last, the plastic covers are susceptible to scratches and very very fragile.
If you guys are happy with your fuel wheels.. good. I would do the anza's or trophys if I had another crack at them. good luck with your decision.
I have the 17" Fuel Anza's with 285 Duratrac's and love them. Get compliments on them all the time.
I would do 17" with 35's, IMO 33's look too small on the JKU.
Edit, depends on the gearing you have. IMO, 4.10's is the minimum if you are doing 35's.
Discussion Starter #10
So my gearing is 3.73... I'm not sure I want all out 35s, what about something closer to 34? I was looking at Nitto Terra Grappler G2 LT305/70R17, or GY Duratrac LT315/70R17. Any opinions on these?
Another question would be, would I be able to get these before I get my lift? or would I have rubbing issues? I know nothing about offset/backspacing, so I don't even know which model of the wheel I would need?
1 - 11 of 11 Posts
