Guys can anyone help me where i can find or buy Fuel Rail Pressure Sensor also known as Common Rail Sensor.
I need it for my wrangler 2.8 Turbo Diesel Wrangler 2009.
Any help be highly appreciated
Thank you
Speaking about VM 2.8CRD in a J8 (or any export CRD) ?
You need the pressure sensor or pressure regulator ?
Both of them are originaly (as per Mopar) available only as a whole common rail assembly.
But it can be obtained from Bosch separately.
For pressure sensor look for any of these Bosch P/Ns : 0281002398, 0281002767, 0281005850, 0281002964 - depends on which version of CR ramp you have
For regulator it can be Bosch 0281002507
If you have fuel pressure problems it can also be sticking M-prop solenoid (at the back of the injection pump) or it can be the cascade flow valve (at the top of the pump) ot the pump itself
As we have a lot of oil burners these parts are quite common in Europe
