Hey all. I've got a 93 wrangler 2.5L that's having some fuel issues. Starting from the beginning, I recently replaced the fuel filter, fuel pump, and also cleaned the tank out really good, along with replacing the relay for the fuel pump. All this was done maybe a year and a half ago. About 6 months ago I started randomly losing fuel pressure. It happened mostly after I'd drive to work. Whenever id get off work it wouldn't want to crank. Usually it would crank after a day or two of sitting. But I wasn't getting any fuel pressure at the motor and when I turned the ignition, I wouldn't hear the pump turning on. It only did this every now and then so I ignored it but now it's been sitting for about a month or two and won't get any fuel pressure at all. I expected maybe the pump was faulty and needed to simply be changed again, but I'm just guessing.
Any ideas on what is going on or something else I could check would be greatly appreciated. Thanks in advance.
