Hello!
Brand new to forum. Just recently bought a 2013 wrangler sport that has the alpine system (sub on back passenger side). I’ve done some considerable research on upgrading the sound and originally wanted to keep the stock head unit to retain steering wheel functions and my Sirius subscription. I read somewhere that in keeping this I’ll lose the ability to control the bass, treble, fade, etc which is a deal breaker for me. The solution involved using the stock amp as a processor and seemed beyond what I’m willing and capable of handling on my own.
So far, I’ve purchased a set of component speakers for the front, 6.5s for the sound bar, a compact 4 channel amp and a separate compact amp/sub package that I was going to put under a seat or mount where the existing sub and trim are (would remove existing factory sub and box).
Admittedly, I’m a total amateur and have not installed an aftermarket system on my own before but I see it as a winter project and I’m eager to dive into it. However, I’m stuck now in identifying what additional components are required with a new head unit to keep steering wheel controls/Sirius. Both amps have stereo level inputs.
Since some of the functionality I’d like to retain functions within the factory amp, I’m trying to figure out what I’d need to keep Sirius, the steering wheel controls, and be able to adjust the sound (think this is accomplished through a new head unit). I believe I need a processor of some sort but not sure specifically what I should be looking for. I also watched a video of an install and there was a 2nd antenna input already behind the dash connecting the factory head unit to the Sirius antenna. If the after market head unit has Sirius is it as simple as connecting the new head unit to that antenna? If so, then the only thing I am missing would be steering wheel controls, which I’d be willing to give up if 2 of my 3 problems were solved.
If the above is true then I think I’m safe to purchase a new head unit with the preamp and sub outputs needed, with Sirius, hands free calling, etc.
Any advice or input is more than appreciated.
