Just changed my oil and installed a fumoto oil drain plug. I used the blue washer that came with and I torqued it to the jeep spec of 20 lbs/ft (I believe that is correct). I'm seeing oil leaking from around the plug. Not the valve/spout, but from around the plug itself.
Any ideas? Maybe torqued too much, need different washer, no washer, thread sealer, something else?
I would hate to loose the oil I jut put in it but if need be to correct it then I guess that's the case.
