1 - 1 of 1 Posts
Having a previous issue with the 30a fuse for the ecu/fuel system. So i checked the fuses under the driverside dash.
Someone on here recommended to check the DOME light fuse. So I pulled it, replaced witha new fuse to be sure and when I pushed it back in, the connection clips seemed to have pushed back into the fuse block. Now the fuse can't connect since the connection is now too far in.
Any advice with how to get that block out so that i can push the connections from the backside of the block so the fuse clips can reach it ? Its a 92. :facepalm:
1 - 1 of 1 Posts
