I am installing a set of three kc lights to threes separate switches. Each light is 100 watts. So mathematically I need a 8.3 amp fuse. Would a 10 amp work just fine?
Is it better to go less amps or more with the fuse?
Fuses are sized to the draw and capacity of the wiring. If you use a size smaller than the load it will blow.
The 10A rating will be fine.
You are using relays though. Not all switchs are rated to handle 8+ amps.
