1 - 18 of 18 Posts
I have seen some past threads, but nothing current. Just purchased a 2010 and every time I fill up my tank the gas overflows all over the ground. I have tried different gas stations. I know the easy fix is to pay attention to the gallons and just manually stop it before it happens, but just didn't know if anyone knows of a fix for this. Thanks.
I had the same problem with my 08 jku. I took it to the dealer and they replace he hose with the check valve. It was covered under warranty.
There have been alot of posts on this and it is a problem. Unfortunately, only 07 & 08 JK's are covered under the TSB. The fix is the fuel fill tube has to be replaced with an updated version. Mine was replaced over 6 months ago in my 10 and it hasn't spilled out since. I have a good relationship with my dealer and they covered it even though they didn't have to. It was replaced as "good will".
...nevermind...
It's under lifetime warranty my 07 did it and I got a letter for it a year ago and finally took it in and got it fixed for free a month ago any jeep dealership has to do it.
I just had mine fixed at dealer. 2007 JK. Lifetime warrenty on check valve. Took about 25 minutes and worked great.
I have an 09 purchased new back then. It just recently started throwing up :( so is it covered under lifetime warranty ?
i think mine already had this done...and its doing it again...no lifetime warranty on mine...
right now...i know about how much it takes when the fuel light comes on...and when i get within 5L...i slow the pump down...
which reminds me...did they put the smaller tanks in the 07's 4door model too? my gas light comes on around 60-65L...but specs show i should have an 85L tank (maybe 80, i can't recall for sure) i've never been too sure, and didn't want to chance it...
I suggest you just call Jeep/Chrysler or take your Wrangler - whatever model year - to a Jeep dealer. I just had the "Check Valve" replaced for a 2007 Wrangler I bought used last month. My Jeep was manufactured outside the dates of the date-range specified for the the original TSB, so I was expecting some push back. But dealer knew right away - based on the VIN - that I qualified for a free check valve replacement as soon as he checked the computer! You've got nothing to lose - just tell them fuel is spitting out and see if you qualify for free repair.
Update: I brought mine in this week and they didn't even blink an eye. No hassles. Fixed it at no cost to me. I'm guessing it's an environmental thing. Way easier/cheaper for Chrysler to fix them then have somebody make a stink about it.
Used 08 Rubi 72K, USA
1 - 18 of 18 Posts
