I need some advice based on experience. I need to replace the gas tank skid on my 98 tj. Them skid is pretty beat up and I have some big dents in the gas tank from the PO. I want to remove the dents and replace the skid with something stronger. I have done some research and there seems to be a few options. A steel box type skid like Kilby, a aluminum style like Saavy, and the newer style OEM skid. I like the Saavy as it is strong, light weight, won't rust, and can provide more clearance. I dont like the added weight of the steel ones. The OEM is inexpensive and from what i have read(I haven't seen one in person) is pretty strong and with the money saved, I can by an oil pan skid and then some. Am I going to regret getting the OEM skid?
I go wheeling maybe 1 or 2 times per month and the trails can be quite rocky but I do not do anything extreme. Is the OEM plate good enough. Will Imregret it?
