1 - 13 of 13 Posts
A few months ago my gauges died randomly. Thanks to the forums i swapped fuses and all was good for a week or two then the gauges died again. I swapped fuses again and then it was good for about a week. Swapped again and lasted a few days. Latest fuse lasted a few hours and now fuse swapping does nothing.
Im sick of bandaids... can someone help me identify what the real problem is? Is there a diagram of where all the grounds should be? I wonder if i have a bad ground... ugh...
I bet it's the printed circuit board behind the instrument cluster if its never been changed. Very easy fix and you can upgrade the dashboard lights at the same time lol
What should you recommend? Resolder the connections? Or if you know of a guide for the repair, that would be great! Thanks! I am at a bit of a loss here...
Do you recommend****
I wish I still had the links for you but I don't. I do remember two great explanations on this forum. One was titled 'How I fixed my gauges" and the another detailed how to actually clean the circut board itself. When I went to clean mine I found it was too far gone and I ended up replacing it with a new one from 4WHEELPARTS and now all of my gauges work perfectly including my 26 year old clock! I have found from other far more experienced forum members than myself that the gauges themselves rarely fail. It's usually other factors involved which can be remedied. I am confident if you started a new thread titled "How can I clean the circuit board behind the instrument cluster" you would get the details for your repair. It takes a little effort but I find it so satisfying when everything on my 87 wrangler works the way it did the day it came off the line. Good luck
I did some more digging, I dont think its the above fix but i could be wrong. All the gauges lose power at the same time as opposed to one or two here or there malfunctioning.
does anyone have a wire diagram they can share please? I would like to try that first before i dive into cleaning and re-soldering my PCB boards...
I have some. I'll try to post them later this evening. It'll most likely be after 9:00 west coast time. Have you looked under there for any shorted out wires? Sounds like you have a short that continues to blow fuses.....
Here's half.......
x2...a short blows fuses,not a bad ground
Discussion Starter · #13 ·
My friend who helped me re-wire everything after i reassembled the dash (it was a rats nest) is going to come help me check for shorts. Endless thanks for the wiring diagrams!!! I hope that is the only issue I have... There was one exposed wire that i wrapped up with some electrical tape. I wouldnt be surprised if there were more.
Here is what under my dash used to look like and also when the problem first occurred:
http://www.wranglerforum.com/f8/help-sudden-loss-of-all-gauges-244812.html
1 - 13 of 13 Posts
