How does this look? I think I finally have it centered from the top to the bottom. Would you agree? It is a little to the heal, (outside of the ring gear). Do I need to center it exactly between the heal and toe? I have pulled it apart 8 times now, but I am actually enjoying the work.
What does your coast side look like? Make sure that they are both close to centered contact and not running out. If that is the worst of the two I'd think you are fine.
Make sure that you are applying tension to your axle shafts in some manor also, easy to over look. I'm thinking it needs to be something like 45 foot lbs while you are spinnng your pinnion around. Imo, would be happy with the pattern. If you get it better congrats!
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
Jeep Wrangler Forum
A forum community dedicated to Jeep Wrangler owners and enthusiasts. Come join the discussion about reviews, performance, trail riding, gear, suspension, tires, classifieds, troubleshooting, maintenance, for all JL, JT, JK, TJ, YJ, and CJ models!
