Im looking at a used JK on a lot. It has a mopar lift with 35" tires on it. It drives like it has been regeared but I cant tell for sure. Based on the picture, it looks like maybe someone has been inside the unit. Thoughts?
You can't look at the pumpkin and know...
Count the revs of the driveshaft for one full revolution of a tire.
Reactions: cameronusmc2001
So just trying to understand...
A 4.10 gearing means 4 driveshaft revolutions per one tire rotation, regardless of tire size?
It's 4.1:1; so 4.1 driveshaft revolutions per one tire rotation and 3.73:1 means 3.73 driveshaft revolutions per one tire rotation
Yep.
3.21 = about 3-1/4
3.73 = about 3-3/4
4.10 = a little more than 4
4.56 = about 4-1/2
4.88 = a little more than 4-3/4
5.13 = not quite 5-1/4
5.38 = between 5-1/4 and 5-1/2
And keep in mind that if you lift only one tire, the number of driveshaft revolutions will be 1/2 what they would if both tires were turning together. This is because of the action of the differential with one tire not turning.
