1 - 20 of 50 Posts
I'm currently running 35s on stock gearing but I want to upgrade so when I get my 37s I'm not tearing out my tranny, any suggestions on gear ratios?
Discussion Starter #7
Looks like a 5.38 would be perfect. Any suggestions on brand?(sorry never messed with gearing before)
What gear ratios you got now?
4.10?
How is it presently with the 35's if 4.10's performance and MPG wise?
Does it require more?
Discussion Starter #10
4.10?
Sluggish and about 12mpg if I drive her easy. That's with the 3.73s. Plenty of torque in 4wd low though. Definitely need lower gearing especially when on the highway trying to do 70mph. Its always trying to drop into lower gears.
Thanks. You also have the 3.8 vs the 3.6
I'm wondering if that makes a difference too
Discussion Starter #12
I know they make a 3.6 for the 2013 wranglers but mine has the 3.8 still needs more motor in my own opinion. I've been looking at supercharger kits to make up for that.
I like 5.38s with 35s in my Rubicon. Can you (still?) get 5.38s with your axles?
The D30 is where the 5.38s are harder to get. I know over the years they simply weren't available, then some popped up and went away, and now it seems they may back again. Post up if you end up getting some and how they work out.
Discussion Starter #18
Now if I get the gears for the rear axle will I need them for the front as well? By all means if it will help me out with daily driving and mountain trails I'm all in.
Yeah, to use 4wd the ratio of the gears in the front and rear must match - there's no option here. If you only use 2wd then they don't have to match - but you'll never be able to shift into 4wd or you'll break something.
Discussion Starter #20
Well its a good thing somebody let me know. Did a little research on the 5.38s for the D30. Go to rustysoffroad.com and search product # D30538JK they cost $180+S&H made by motion gears.
1 - 20 of 50 Posts
