1 - 16 of 16 Posts
What gears do you all think I should have in my jeep? I't an 03 rubicon with 35 inch tires. And do I need to replace both front and back or what?
Well if its a manual, then 4.88s will be fine, if it's an auto, it's kindof a toss up between 4.88s and 5.13's depending on if you have the O.D. button (over Drive button)
Yes, both front & back need replaced and labor is typically any where from $750-$1000 to have both front & rear done. The gears & master install kits are relatively cheap, compared to the install labor.
that's what she said
i think that 4.88 are overkill, especially if you are using it as a daily driver. the rubicons came equipped with dana 44's and 4.10. if you are dead set on regearing, 4.56 would be the highest i'd go. my cj7 is a trail rig only, it has dana 44's with 4.10's front and rear with 34" tires. here is a good chart to go by, depending on what you want to accomplish.
Yea, but with the 4.88's it covers using 35's and/or 36's for tires.
Plus if you look around most Rubicon owners are using 4.88s. I don't believe that 4.56 is an option for the Rubicon differentials.
My ole man runs 35's and he runs all over the place with stock gearing. The 4 to 1 transfer case makes up the difference and he hasn't complained yet.
i agree. i decided to go with terra low 4:1 kit for my dana 300 rather than regearing. i am very happy with the results.
Commercial MemberX
Ahhh ole school Dana 300 hehe....they were a good unit though
I think alot of people way overgear....we have a few around here that do it as well, and when it comes time to get up something and you need some wheel speed....they no havey hehe I mean seriously, a 5.13 for a 35" tire? I run a 5.13 on a 42" tire with a 2 to 1 transfer case.
If I threw 5.13's in my Rubi it would cover a board range of tire sizes and would only have to regear once and could run 35's-37's with no issues. There's been too many times where I've seen people regear and then move to a even bigger tire and then regear again.
Yea the stock gears can handle the 35's for the rubi, but I would atleast recommend Alloy shafts. I dont think the 4:1 Tcase has anything to do with the daily driving or street driving. The benefit of that is when finally offroad & crawling.
Commercial MemberX
Exactly, that's the reason its there so you don't have to go with stupid low gears and loose mileage and reliability. With a 5.13, a 4 to 1 case, and 37's you couldn't create enough wheel speed to go through the smallest of mudholes. The only thing it would be good for is slow on rocks....hell I run a 5.13 on a 44" tire on the street and sometimes that is too low.
Well I wheel with a group of Rubis at the Badlands offroad park alot, and most are on 4.88s or 5.13s and running 35's to 37's and running the trails and rock crawls just fine.
Discussion Starter · #12 ·
Ibuildembig said:
I still bet that my ole man's would follow you around just fine with the stock 4.10's.
I'm asking cuz it seems that I have to down shift a lot in my rig with the lift and bigger tires. But in my fiance's dad's I don. As much and his is stock with a smaller engine
Commercial MemberX
Well there are several factors that you need to think about. A stock 4.0 5 speed on baby stock tires will run pretty good. The weight alone you have added will slow you down some. His jeep mighta had a different set of gears put in it at one time too..who knows.
1 - 16 of 16 Posts
