Genright or Synergy
1 - 20 of 27 Posts
Sporticus
I have about $10k and need advice, i wanna swap to a 3 link 4 link and coilovers. it pretty much completes my build. ilike both but feel genright has more of a complete kit??? any advice, i would love to see pics to!!!
THANX!
Sporticus
SHOPPING CART
genright shopping cart??
ProductPriceOrder QtyTotal KING 2.0" Coilover Shocks, w/RES, Pair
Shock Travel 14" (KING2014COR)
For Use on: Rear$1,300.00
$1,199.99$1,199.99KING 2.0" Coilover Shocks, w/RES, Pair
For Use on: Front$1,300.00
$1,199.99$1,199.99Coilover Shock Hoop Kit, Front
Add Choice of Shocks None, thanks$299.99$299.99Outboard Rear Shock Mount Kit
Shocks Choice No Shocks, thanks
Options: None, thanks$299.99$299.993 Link Front Kit, with Links
Upgrades 1-1/4" Johnny Joints
Jeep Model: TJ / LJ$1,450.00
$1,199.99$1,199.994 Link Rear Kit, with Links
Optional Axle Bridge No, Thanks
Joint UPGRADE No Thanks$1,250.00
$1,099.99$1,099.99Currie Anti Rock Sway Bar Kit, REAR$399.99$399.99Make any changes above?
Subtotal: $5,699.93
Poly was the first to come out with the frame brackets, just an FYI. Shop smarter and you can do a lot better $$-wise on coilovers unless you just have to have Kings. I'd call up both and see what they can do for you on total price. Ordering that much stuff should definitely get you a discount.
Sporticus
thanx and what would you recommend for coilovers???? i emailed both today so well see what happens.
Call, don't email. As for CO's, have you done any research on them? I'd suggest you spend some hours doing that. Swapping to CO's is a bit more complex than bolting them up and going. IMO, Kings are great but there are better values out there. I've been looking at 2.0 Fox's and Radflo's for the rear and 2.5" for the front. You'll get much better (and more) answers over on Pirate. I'd research the topics first.
FYI, I run the Poly (Synergy) mounts and built my suspension around them.
Sporticus
thanx, i would call but i am currently deployed overseas as i usually am quite a bit. i just put brand new g2 dana 44s on it and im runnin procomp 35s an might go 37s if i truss the rear axle, not sure yet.
Drives by Braille
Are you planing on stretching the wheelbase at all? For the 3 & 4 link "kits" there is a lot of fab work involved... what about a truss on the rear? What about your exhaust? Why coil-overs?
I can see wanting to toss wads of cash at your Jeep... but what are you honestly trying to accomplish?
If you'd like an easier route... I'd suggest a long arm kit from Rock Krawler or Clayton. Everything is already thought out. Plus you can still have a damn good suspension with some very nice shocks and coil springs. Check out some of Rawkon's videos with his Fox Shocks.
Sporticus
Discussion Starter · #11 ·
i do want to stretch the rear 5", relocate the gas tank and improve my ride quality, plus i do plan on 60s, hydro assist steering, and 44 inch tires sometime here in the future.
Drives by Braille
If you are saying "in the future" ... how far away is that? I mean, you just put in D44's... if you got money to blow, buy me an 8.8 :D
For the price of just the 3link and 4link you are looking at, you can just about buy a full on Clayton kit. Then just buy some REALLY good Fox Shocks and you'd be pretty well off.
Youre building all backwards.
Buy the stretch kit and 3 link and 4 link now, then buy the 60's, hydro assist, and tires and coilovers...
Sporticus
Discussion Starter · #14 ·
i plan on stretching it with the 3 and 4 link, the 3 and 4 link will cost me about $2300.
Sporticus
Discussion Starter · #16 ·
i wanna stretch front and rear but not sure what all that in volves, rear is just relocating gas tank, brakelines, and a longer driveshaft correct? front im still not sure on? tryin to do my research, any advice or answers?
Sporticus
Discussion Starter · #17 ·
hey man, didnt even notice it was you, hows it goin, any good runs lately?
How much of a stretch do you want? I would just stretch the back. The RK kit brings it to 102'' thats perfect for the TJ's. I can see what it takes to use FOX or KING instead of RK coil overs
Sporticus
Discussion Starter · #19 ·
i do kinda wanna stretch the front and gain a better approach angle.... my stinger would still protect and not be in my way of makin a climb....
1 - 20 of 27 Posts
