35'sWhat size tires?
I replaced ours with name brand bearings. They originals weren't bad, but since I was taking it that far apart to install axle shafts I figured I might as well replace the bearings while I was in there. Nothing special about the bearings I used. And they are still good some 30,000 miles later. And we are running 37's. Keep in mind the D30 and D44 use the same wheel bearings as I recall. So you should be good with up to 35" tires with the D30 wheel bearings. And some, like us, run 37's with those wheel bearings. We wheel fairly hard, but not extreme.
35" wheel offset is -38 no spacersWhat size tires and what is the wheel offset. any spacers?
I read the timken studs are not flared out like factory according to many amazon reviews. This worries me from buying those. I also heard the wheel speed sensor is not long enough @JTPhoto JKI use nothing but Mopar or Timken bearings. No issues with them when running 37” Pitbulls. My last set of Timkens lasted 152,000klm (95,000mi).
If the wheel speed sensor isn’t long enough that person ordered for the wrong year. Newer JKs have a longer wire. As for studs, I Have never had an issue with Timken wheel studs.I read the timken studs are not flared out like factory according to many amazon reviews. This worries me from buying those. I also heard the wheel speed sensor is not long enough @JTPhoto JK
O nice. I'm surprised no aftermarket alternatives have been made for stronger wheel bearings under $250 each thoughThere was research done on this some time ago. There is only one manufacturer for ALL the unit bearings. However, they do produce different quality levels for different buyers. Mopar, Timken and SKF are top tier.
Another reason I won't sell my lifetime warranty back to FCA.O nice. I'm surprised no aftermarket alternatives have been made for stronger wheel bearings under $250 each though
