1 - 20 of 29 Posts
Had my Jeep for a few months. Had it tuned up, but had to get GM hoses to replace the old GM parts that were there so it would match up. Having some minor issues now, ordered a coil, but it had to be a GM coil to match up with the GM distributor. The guy even told me today that there weren't any Jeep parts on it, mostly GM. How can a Jeep (Chrysler) support parts from another make (GM)? Has anyone else run into anything like this?
stock radiator cap is a GM part as well.
So this kind of thing is normal? I wasn't sure if this was common, or if the PO made a bunch of these changes, which could be the reason for the problems I've been having with my jeep.
last time I checked the YJ was an AMC product. the Mopar influence didn't hit until 92 and even then still mostly an AMC product. and being an AMC product they sourced a lot of GM
Well, mine's a '90, so it would fall before the '92 Mopar influence. Thanks for the replies. The way the mechanic talked, this was out of the ordinary and not the way it was supposed to be.
AMC means Any Motor Company. They used parts from anyone they could get their hands on. Some even used Motorcraft ignition parts. AMC was to poor to engineer their own parts. It was easier to rob from others.
In a trailer in the woods
This is very true. Not unusual to find GM or Ford parts in the AMC years.
This is common knowledge among a lot of YJ enthusiasts.Dont change mechanics but just do some Jeep homework and just learn for yourself when changes were made at Jeep corp.If you are a Jeeper for life then it can be a very valuable education,and being my own mechanic for 24 years I have found that Willy's/ Jeep CJ's ,YJ,TJ Wranglers etc... are some of the easiest vehicles you could work on .
Discussion Starter #13
Yes, I'm a new Jeeper, so I'm learning all about the ins and outs of my YJ.
like someone said before the 2.5 aka is the iron duke by gm.. if u know of a cherokee from 84-86 and it has a 2.8 in it. thats the gm 2.8.... if u have a 4.2 then it should have the ford ignition... steering columns are pretty much out of like the old chevy trucks.. back in the day i believe they used a buick 3.8 in some of the cjs... and believe it or not the ax15 trans is the same as the toyota r150f except the input and output shaft are different. and the aw4 i believe is also a yota trans. just different parts so it bolts in the jeep... there is some examples that i can think of right now.
Electrical Guy
^Yea, the steering columns in the older jeeps is the Chevy truck column, I've grabbed parts from one in the junk yard once for my truck.
You are correct that AMC did source parts from other makers. Taken another way, it helps to keep costs down (and profit up) to use a distributor from GM or a Borg-Warner or Chrysler automatic transmission (both examples on late 60s /70s AMC) or later a Ford sourced ignition on the original YJs. Why engineer another part when you don't have to? Ask yourself why does Motorola supply alternators to many makers?
If AMC made a mistake, it was the 70s Matador coupe that sent the company down the tubes. Nice enough car (and I like Teague styled cars!), but it just didn't sell enough to justify the cost of producing it.
Another thing that really hurt AMC was the UAW. Yeah, that's not a PC subject to bring up in today as the U.S. races for equitable re-distribution of everything, but the UAW really bent AMC over. Those costs drove AMC into the arms of Renault and the rest is history.
With rare exception, AMC engines are AMC produced (Iron Duke 4-banger from GM for an exception). The 390 V8 was not a Ford engine, etc. The bodies were all AMC and they had many innovations (first all plastic interior is a weird example, but all cars are that way now).
Chrysler bought AMC in 1987 for one reason -Jeep. At least give AMC props for keeping Jeep alive after mismanagement by Kaiser.
I remember reading about the 2.8 chevy motors in cherokees,do you know if they used a borg warner tranny or did they use an AMC product ? Googling but not really finding anything on that .
Electrical Guy
According to wikipedia.......(I know it may not be accurate.)
http://en.wikipedia.org/wiki/Jeep_Cherokee_(XJ)
1984-only : Borg-Warner T-5 5-speed manual, used with 2.5 L I4 and 2.8 L V6, 21 spline output.
1984 – 2000 : Aisin-Warner AX5 5-speed manual, used with 2.5 L I4, 2.1 L I4 diesel, and 2.8 L V6, 21 spline output.
1 - 20 of 29 Posts
