1 - 20 of 35 Posts
So im taking a group of guys up to big bear. Two jeeps. A four door JK on 35" and my TJ on 33". Neither have lockers or a winch. Would it be a good idea to run the trail? We have recovery equipment.
Scottie- Nooooo..I had to strap someone off the rock garden..it's not That easy..but your rigs will make it no problem. OHH! And look for my license plate I H8RDS. It was taken off and left behind :(
Lorie :thumb:
:crazy:
I ran it stock in a JKU. There was some carnage that weekend (one guy broke a DS, and another broke his hard top) but if you ask me, the trail was pretty tame, both of those failures had little to do with the trail itself. :doh:
Exactly- it ain't always rig capabilities :whistling:
I say go for the GM run. It is probably my favorite trail in BB for just getting out. Use good judgment and stay off of the skinny pedel in the technical areas and you will be fine. I have gotten a bone stock YJ with 29" street tires through it with only a light tug. Very fun and scenic.
Jeff
Really glad to get all the responses. I will definitely take the trail. Tell me more about Holcomb creek.. Id say I'm a fairly good driver but my buddy doesn't have as much experience...
Does holcomb creek follow the actual creek? I see the creek on map but not trail. Wheres the start?
Here's everything you need Holcomb Creek Trail - Dirtopia, the Off-Road Encyclopedia
It's a bit more technical, IMHO... definitely need a lift for Holcomb, although some have been known to run it stock :whistling: (but only with a lot of help)
There's really so much good wheeling around there, you can hardly go wrong. If you post as to when you'll be going too, I bet you'll be able to get a few more people to join you and show you some of the trails.
Good trail! Few good rock gardens..Gorgeous! I've helped maintain that trail. You'll be able to make it without a locker, but actual trail recommendations are at least a rear locker and 33's.
I'll let someone else give you GPS coords; as I don't have GPS.
Discussion Starter · #13 ·
hmm. I have plans for sliders but haven't made a set yet.. :( maybe I'll skip out on Holcomb. Gold Mountain starts on the 18 and goes north or is it wheeled the opposite direction? I'll be camping at Little Bear so it's kinda on the opposite side of the Lake. Any good Mines in between the camp and trail we could check out? Like ones that we could climb down in?
Discussion Starter · #15 ·
suicideking said:
Ya, skip Holcomb until you get rails. GM will be fine. Fun trail, scenic too! I wish it was longer.
Will do! Still looking for one more trail though. Any suggestions anyone? Also if any of the mines are particularly interesting let me know.
Jacoby Canyon Trail any good?
Jacoby is actually the first trail I did in Big Bear back when I had my Cherokee. It's nice and scenic and has a few little fun spots that are passable by a stock 4wd.
If you're looking for a nice day of scenic wheelin with some semi-newbie Jeepers I'd do Gold Mountain to Jacoby or might be easier to do Jacoby from the backside up and then to Gold Mountain down.
Good luck and have fun! :thumb:
Agree with this. Jacoby is easier than Gold Mtn, mostly scenic. If you go up GM, it's right next to where it ends.
Discussion Starter · #19 ·
Hmm im thinking we'll do GM first thing in the morn then find a different trail for the afternoon. Maybe jacoby. Yall make it seem too easy though ;)
Here is a fun run you can do (if it's not to far of a drive). Off highway 38 (a few miles past Onyx Summit-not too from Big Bear) take 2n01, make a right on 2n61y. A few miles you will have the option to do 2n61ya (Pontiac Sluice). Pontiac Sluice is an out an back. Just past half way you get to a "y". You can go either way as you will end up at the same place (back at the 'y'). I think right is the better way. Anyway this is a fun out and back thru a rocky trail, but not real hard. When you get back to 2n61y, go right and continue on. There is only one real obstacle that will challenge you. Take your time and figure it out. 2n61y will end at 2n02, go left. If you enjoyed Pontiac Sluice and 2n61y and want just a bit more of a challenge (only a little bit harder) take a left on 2n69y. This is a black diamond trail, but it is not very hard. The three times I have done it, no one has ever needed a spot. This trail will take you back on to 2n02. Make a left on 2n02 and this will take you to 2n01. You can make a left on 2n01 and head back to the 38. Or you can keep going and look to the left for a mine you can walk in and check out. (I have not done this, but have seen people stopped there) Or you can make the drive up to Tiptop Mtn. Or you could take 2n02 all the way to Baldwin Lake (close to Big Bear). ( I have not done this, just seen it on the map) As you can see you will have lots of options on trails you all can make. PM me if you want more info...
1 - 20 of 35 Posts
