1 - 20 of 28 Posts
Shes looking legit, i broke the tires in right. 35x12.50x17 procomp extreme terrain
Kevinm2467 said:
That's the look I'm looking for... How did you cut you fender flares?
I left them on the jeep, taped off how i wanted it cut, and then cut it with a dremel and rotary wheel. Then i used a utility knife to trim the burned plastic off. I used a hacksaw to cut the supports, then went to advance auto parts and bought some black uchannel door molding and put it on the fenders.
Retired Moderator
Discussion Starter · #11 ·
Thanks for all the compliments
Discussion Starter · #13 ·
seadog said:
What did you end up doing with the front side markers?
I havent done anything yet, im gonna do the project jk writeup for it, i believe he used a 3/8s inch circle light marker and placed it in a predrilled hole.
looks great.....I would like to see the marker light set up when you do it....
The Bad Guy
It looks good, but sooner or later you are going to have an issue with your tail gate.
Discussion Starter · #17 ·
Haha i knew someone was gonna say that, that rear spare is actually a rubicon pulloff, it just looks as big as the others because of the angle of the picture. I wont be able to afford a 5th 35 until feb. I wont buy a 35 for the spare until i get a tire carrier on the rear.
The Bad Guy
You really can't tell from the picture, especially since you have the same wheel! How do you like the Bestop rack? What kinds of things do you use it for?
1 - 20 of 28 Posts
