i have a 95 grand cherokee. it has about 160k on it. i know its not a wrangler but i don't know who else to ask. it is leaking some oil and from what i can see it is coming from the distributer. looks to me as if was coming from the bottom but i am not sure and i was just wondering if anyone has had this problem and if they knew what to do. thanks
Out under the cap, or at the bottom where the distributor goes into the block? If number two, there is an oil gasket that goes under the lip on the bottom of the distributor to prevent leaks, and may be alleviated if you tighten the dist. retaining clamp bolt. If it's leaking from under the cap?????? I don't know what to tell you.
