From the start, When I got the jeep a yr ago, it had a 2.5 lift. 16" rims and I think 245/75R/16. They were badly worn, due to improper shock install, and I doubt he ever rotated his tires. When driving, from about 45-50 mph, I will get a shimmy/wobble in the steering wheel. It doesn't happen at lower speeds, nor higher speeds.
I replaced lift with Zone 4.25 lift, and Metalcloak control arm. The shimmy was still there.
I just got new 15" rims and Duratrac 33 tires. Sigh, shimmy is still there. Everywhere I had read, people seem to say it is usually tire balance. But since I replaced rims and tires, I find it hard to believe that it could be tire balance, since the shimmy is at the EXACT same speed.
I have done the dry steer test, and never found anything loose. I also jcked up the front end and checked the wheels for wobble, to test the bearing, and all was ok. Any suggestions?
