1 - 17 of 17 Posts
2020 JL Wrangler 2Dr
I have a new 2011 2 dr JK Sport without an OEM GPS and want to buy a Garmin to mount atop the dash in that rectangular pocket above the radio. Has anyone found a good way to secure a GPS in this location? Thanks
Retired Moderator
i secure my garmin to the window and it works great there and there is no extra dash disc to leave when i put it away
On my 2007, and now my 2011, I use the Garmin Friction Mount. I liked it so well, I got one for my wife's Ford Edge.
Amazon.com: Garmin Portable Friction Mount: Electronics
I set it either in the tray or just to the left of the tray on the dash. Convenient locations and it never moves when traveling.
USAntigoon said:
My GPS mount is on the driver side... The position on the center console will play havoc with the compass..and it obstructs the forward view more in comparison with the LH side..
Compass is dead on after recalibration. Top of GPS is below sightline of hood front edge; don't have turn to view
I have a 2011. With the suction cup attachment, it slides right into the cubby hole below the stereo. Fits perfect, and doesn't move.
Discussion Starter · #14 ·
Thanks for the ideas. BBARQUIST, I like your set-up. I just sent an email to daystar and will probably wait till the 2011 dash mat comes out. I like the middle location since my wife can get to it while we are driving and check out routes and POI's. Thanks again for the great suggestions.
I picked up a schoshe gps mount, I mounted it to the daystar panel. but it is adhesive backed pad. If you look at my photos I posted some pics of the setup. I hardwierd the GPS and my Iphone charger/Stereo adapter cord.
It's a couple steel tubes and some metal plates. It has flat bar welded to the front and back for mounting.
A little welding and grinding and two cans of spray paint.
If I make another I'll use a c channel instead of the tubes so I can hide all the wiring easier.
It kinda looks cheap in my brand new jeep so I'm gona take it out and re-sand and paint it. Plus the bolts need to be something pretty too. maybe painted black or stainless steel. It took me about 2 hours.
Eh... maybe I'll just make a new one for some minor improvements.
It's mounted to the metal under the plastic cover at the front and the plastic overhead sound bar in the back. I had to cut a little of the front plastic cover to get it to fit nice.
I woundn't hang on it but it'll hold all the components I need.
I have a CB on the front and some accessory switches on the back. I'm gona add an XM radio to the front.
If I remake it I'll get measurements and materials for any DIYer who wants to make one.
1 - 17 of 17 Posts
