Hi anybody, I tried searching but couldn't find what I was looking for.
I have an 88 yj with a 4" lift. I need to replace the stock leaf spring shackles but want to replace with greasable ones. The stock ones are 4" center to center. Any suggestions ? Not looking for any bigger lift. I know I might get a little lift because the shackle size will be a bit longer.
thanks:pullinghair:
It's not the shackles themselves, but the bolts and sleeves in the bushings that make them greasable. You can get the bolts separately,and save a few bucks, if you have newer spring bushings, but you might as well replace the bushings while you are at it, if needed.
Daystar has a set for $57 and change right now on Amazon, FYI, Daystar is what RE uses on their kits, OME has proprietary bushings that use stock the bolts.
I would try and verify your leaf spring brand before shopping to far...
Got it at last, I ordered some from XT. I actually called and spoke to someone about what I needed and the type of lift and leaf springs I have. Should be here by the end of the week. I also got some new bushings the other ends of the leaf springs.
Their is good info on this site, I appreciate people.
midessa7
Glad to see you did your homework, Nothing disappoints more than opening the box and finding out you got parts that don't fit.LOL
Have fun.
