Now I have found out that my 2004 X has 7 grease fittings (zerk) in the front. Given that I have to carry a grease gun down to Cozumel to do the job the question is:
Is there a special size for the zerk fittings?
Dave Dillehay
Its a normal zerk fitting. My suggestion is to use a grease gun that has a flex hose, or a small grease gun so that you can access all the fittings.
I use one of these:
Grease Gun with 3 Oz. Grease
Knows a couple things...
Yes you will definitely need a grease gun with a flex hose, otherwise it won't be able to fit in to get to all the fittings. And X2, it's a standard size zerk fitting.
