Hubby is wheeling the Rubi today with Ageless and some others, and he said he hit a rock and the airbag light kept coming on for a while and now he has a check engine light.... He will be calling shortly to find out how to read the codes he gets. Any help is greatly appreciated...
Also he torked up the sway bar disconnect with the same rock....
It's flashing at him too I think.... And he put a dent in the rear bumper that matches the one our brake guy put in it last week...
I'm so excited I could just spit!
Thanks guys and girls!
OK, I found how to check the codes...
1. To check your Jeep JK Wrangler’s DTC codes, simply insert your key into the ignition, turn it to the ‘ON’ position but do not start the engine. Then, push the key into the ignition cylinder and while holding it in, turn it to the ‘OFF’ position and then back to the ‘ON’ position (3) times straight making sure to end with it in the ‘ON’ position. It is important to keep pushing in on the key to prevent it from catching at the different positions along the way.
2. If you do step #1 correctly, all your dash lights will illuminate and your odometer will show up as a series of (6) dashes. If your Jeep JK Wrangler has any logged in any DTC’s, they will be displayed soon after the dashes appear. Write down the DTC(s) and check it/them against the list to find out what they mean.
3. If your Jeep JK Wrangler has not logged in any DTC’s, the dashes on your odometer will be followed by the message ‘-done-’. Turn your key to the ‘OFF’ position and you will in fact be done.
Any clues as to what he should be looking for?
