1 - 10 of 10 Posts
So i was about to install some red lights to light up the foot area in the jeep, and i was stupid and never disconnected the battery, so when i cut one of the wires my interior lights went out, radio, and gauges.
On the gauge cluster all theblinker works and the high beam plus all the other lights, just the dials and odometer dont register.
What fuse could this be? i checked a couple of the ones from the glove box and they seemed okay.
bueller?
Chances are you cut a wrong wire as cutting wires isn't going to blow fuses, touching said wire to a ground though and shorting it will blow a fuse.
^ Reconnect the wire you cut.
Don't cut wires unless you know what they do.
sparky said:
^ reconnect the wire you cut.
x2!!!!!
Take out old bulb and replace with red led... :confused:
I blew the 10 amp iod fuse, replaced that and it's all good now, yeah now i have red lights on the inside. Ill wait till it gets dark and ill show you guys a picture.
I just got led strips from autozone and hard wired them to the positive and negative where the bulbs are connected, i can run the bulbs and the led's at the same time if i want to.
It was not the wrong wire that i cut, it just made a short when i cut it so the fuse blew, no big deal.
here it is
woops here you go
1 - 10 of 10 Posts
