Just wondering since I don't know much about the hard tops but will an 07 hard top fit an 11. An also will the 11 soft top work on the 07. Im pretty sure the soft top would but not sure about the hardtop
See the sticky about Soft Tops. The short answer is any OEM top for an older JK will fit. The catch is you must have all the parts from the same top design.
07 and 08 hardtops are different. The center latch is up the middle from the footman loop. 09 and up use the footman loop for the center latch. The footman loop moved a couple of inches to the driver side that year as well.
Folks have mentioned just not using the center latch.
Bob K.
Bob K.
Thabks I appreciate it
Just FYI my 07 soft top fits great on my 2013 jk.. Just remove the center bar right above the rear view mirror and all will be good to go . But you must have all of the 07 hardware also ..
