1 - 12 of 12 Posts
Can anyone clear up 4 me what lift will get my 2016 Hard Rock to the same height as a regular Rubicon with a 3 1/2" lift. I dont rock crawl but need the height for access to my mountain home. I will be running 35x12.50 / 17's. I want to use either the Rubicon express or Teraflex. I dont want chinese shocks or any other foreign parts if possible. Thanks in advance.
Waiting for my 16 Hard Rock... Loaded less touch screen & nav.
The suspension on an HR is identical to a "regular" Rubicon.... so the answer to your question is "The same lift that's on the Rubicon you're using as a reference"...
Pick your poison... there are plenty of choices....
That said... you don't need 3.5" to fit those tires... 2.5" is plenty.... The reason I say this is that at 3.5" you're right at the edge where you really need to replace a bunch of expensive parts to "do it right" -- with 2.5", you can get away with springs, shocks, bump stops and that's about it.
Thanks 4 the info guys. Yes my place is deep in the Southern CO Rockies. I am above 8,000 ft.and over 10 miles to the nearest hard road. Yes, its a house not a cabin. The snow isnt really the issue. Its the mud thats soft & sticky. I will start off with the 2 1/2" for now. I bought a new 2500 cclb dsl Ram 4x4 lbox with 3" lift & 35's and barely am able to make it in the spring. All 4 Nitto MT 35's spinnining. Rock on..
I'd love to live 10 miles from paved roads!
I don't want to start an internet whizzing contest here, but I think Your Jeep will do much better than your pickup truck. I know know, I love my pickup too!
It sounds like traction in the mud is more of an issue than clearing large obstacles, so maybe someone can suggest a good mud tire?
I agree with pkai, 2.5" lift will most likely do.
Does anyone know if a 35x12.50/17 tire will fit in the stock Hard Rock OEM rear bumper?
It will fit with a spacer and longer rubber bumper cushions. Your 3rd tail light will be barely vusible. A friend has had one for a couple of years with no issues.... BUT he does not off-road at all.
The OEM carrier was NOT designed for that much weight and eventually, you will screw up the tailgate if you off-road at all or even drive rough roads hitting bumps, etc..... There are several solutions to reinforce/replace the hinges or replace the carrier altogether. Search around you will find plenty of info.
Get the Teraflex 3" spring kit and their 9550 shocks, bolt on your wheels and tires and don't look back.
If you have a little extra cash, get the Fox shocks and their HD track bar.
1 - 12 of 12 Posts
