What are you guys using for hard to reach zerk fittings? I have a lower ball joint that the installer has facing the axel that I can not get on. It is recessed a little which makes it worse. Thanks.
too recessed.Would a right angle grease coupling work, or is it too recessed?
I will take a pic later. I am at work now. I did get grease into it now. Had to put a larger 45 degree zerk to fill it and then put the original back on since I was afraid the knuckles would hit it. Took about 2 hours for 2 fittings. Pain in the ass.A pic of the zerk would be helpful.
Unfortunately I am running the Synergy ones. I did not know they were not the good ones until after I had them installed. It was a quick decision to have them done while I was getting the axel regeared and the axel shafts replaced with chromolly shafts.What kind of ball joints are you running? The upgraded Spicers I installed last year only have a zerk on the top ball joint, I'd hate to have to grease the bottom joint with its limited access.
