I put my hardtop on about a month ago.
I now have a water leak. The water is pooling behind the passenger seat.
I sat in the rig when it was raining and found water dripping from the front most hardtop bolt on the passenger side.
I can't for the life of me figure out how to stop this or how the water is ending up
at that bolt.
The door seals are all good and the top appears to be on correctly. All the hard top bolts are snug.
If anyone else has had this issue out has thoughts they are appreciated.
Funny I had zero leaks with the soft top!
Discussion Starter · #4 · (Edited)
Mine did that until I went from half doors with sliders to full doors
Thanks I have full doors
Are you missing your muck seals? They are a little rubber seal piece that sometimes sticks to the soft top door surrounds. They look like this;
https://www.quadratec.com/p/crown-automotive/Pass-side-mucket-seal-wrangler-tj-unlimited-55177256AB
It fits over the front corner of your tub, and is held in place by a little pin.
I checked and the muck seals are in place.
I'll have to keep looking and find the path of this water leak.
Thx
2021 JLUR Sarge Green
Go to Home Depot and purchase a roll (or two) of window sealer and run it along the door frame and hard top....solved my problem
