I recently purchased a Tank 2015 2Dr Willy's Wheeler with a hard top. The last Jk I owned had a soft top.
How much does the top weigh?
Has anybody had any issues with the quick release bolts?
Anyone know the dimensions of the hard top? It has been cold so I have not measured yet.
If you store your hard top outside:
How do you store it (cover etc.)?
What issues have you had?
Thanks
Desert Dweller
According to my scale, my 2012 2 door top with Freedom panels weighs 136 lbs. Each power / heated mirrored door weighs 62 lbs.
Mine hangs from the garage ceiling on a Lange hard top hoist. Still from the same eye-bolt I put up when I had my TJ, though I do also have "safety chains" on mine - 3 smaller eye bolts with chains/spring clips going to the "J" hooks.
All the weight does still hang on the cable/single eye bolt, but should that fail, there's maybe an inch or 2 of slack in the safety chains to keep it from crashing to the ground.
No quick-release bolts on mine. Soft top for summer so when it's time to change, turning 6 bolts isn't the hardest part of the job.
